Wow! I just learnt so much! I was able to solve the problem thanks very much to you! I have one remaining issue. For some reason, each time I exit IGO, either when turning off the car or when manually exiting out of the IGO program, it forgets the GPS settings and I have to go into IGO settings, deselect whatever port is selected and do an Autodetect. It quickly finds the GPS and off I go.zedd wrote: Go to the GPS settings, browse for the folder and then the executable. Save that path and IGO should load again. That is also how you change from IGO to one of the GPS programs or update IGO to a new version. You load the new GPS software on the SD card, change the path, pick the executable and away you go with another GPS package.
Does it sound like this is something else I've stuffed up somehow? It's weird because the program that IGO runs on top off shows full GPS contact when I check its settings.
Also, I was able to load the IGO program out of my parent's car (with a 7" system) and the same thing ocurred...it needs autodetect to find the GPS!
And then I loaded the latest Primo IGO 2011 maps I bought online, and everything worked fine, except it sat on "Auto detecting GPS" and didn't find it, and I couldn't find a manual setting to do anything about it. But I hope I can get the latest Primo maps working because I prefer the layout and all the extras it includes...currencies, calculator, shoe sizes!!!, etc.
