if your going a new amp and head unit do the following ,, my car had a bad stereo install in 1994 and it was done by a pro :/ omg how things have changed , no in line fuse and every thing was taped together :/ so i run a chunky power wire from the batery next to the ac pipe. theres a hole there with a wire, i just cut the hole bigger and run it through, put in a 500watt briged amp to 100watt with a jbl subwoffer on the back seat or in the boot, then i installed a jvc head unit from scratch as the stock harness was all cut up and messy so i installed new switch power cnad found a constent power in the loom. then i run all new heavey dudy speaker wire through to the back and front and then put in some okld home theter speakers in the parcle shelf under the carpet
then some 5inch fusion two way speakers,
fusion is a great brand for quality and price . if you got no money but want good soud then go fusion .. if you can afford it get better
but realy the only ones that would fit in the stock holes were the fusions and jvc splits .. if your up to it cut the stock mounting holes out all together and then make your own mount ..
my stereo sounds mad. it goes loud and still sounds ok .. but when you turn t down its amazing ;P
need help inbox
