A while back when I was working on the rear hatch, I noticed holes for what I assumed used with speakers.
Now wondering, rather than butcher the parcel shelf (rattling bastard of a thing) why not mount some subs in there.
Anyone done this?
Too rattly?
Ineffective?
Also. Ive installed a Clarion 4 channel amp and have not used the remote (sens.) wire (accessory 12v). Ive just bridged the 12v batt to the remote terminal. As yet I have not had a flat battery (standby current drain must be low), but is this really good practice?
Many thanks,
Gonz.
Subs in rear hatch?
Nah dude that blue wire only gets like a small pulse from the blue remote wire on ur unit, it,s not ment to get a continual current of 12v, u may fry sum thing in ur amp, or decreese it's life span?
Yeh it can be attached via the accessory wire but the unit just sends enuff signal to switch it on & switch it off .
Hope this helps
P.s post a pic of where u lookin to position the sub, mite be able to help with ideas, I'm toying with a couple ideas for my own?
Hope this helps
Thanks for your reply.
Will take a pic of a hatch and post it for ya.
Managed to find the Clarion manual. Should be pretty basic to wire DC to it. HOWEVER if nothing is connected to the REM terminal (I called it remote....my bad) then nothing works.
Its labeled "Remote turn-on input". I assumed it was a 12v sens wire from the accessory. No further mention about it in the manual. Any way, with 12volts on it, everything works fine.
Remote power wire comes from the head unit. Running the amp with permanent power will drain the battery fairly quickly if it's a s**t battery
Also I doubt you'll fit a sub in the tailgate let alone have it sound any good
haven't measured the holes but I'm fairly certain they would be 4 inch.
Insert sig here
Are u talkin bout the side panels in the boot that the parcel tray rests on?
They look like a 5x7 holes, I've got a pair that'll fit Poyfect in that spot!
I want a nice clean parcel tray everything is goin in a factory position except the subs and amps ofcourse but all speakers have a spot!
Peeps are gonna loose there s**t wen they see wots coming from Lil Swifty G !
More Bounce to the Ounce !
BaNg!
P.s u may have 2 blue wires coming from ur unit 1 with a white stripe 1 solid blue , usually solid blue will be ur remote/trigger (rem) & the white striped 1 will be for a power antenna?
BaNg!
Dude. We aren't a bunch of twelve year olds on MySpace. Just talk normally.....Oniddog wrote:Are u talkin bout the side panels in the boot that the parcel tray rests on?
BaNg!
CONVO RACING
NICOLEHUNTERS
Cynthia the Convo Racer
NICOLEHUNTERS
Rasputin wrote:I have a solid question.
Same as the "vents" on the qtr trims either side of the rear seatFyrestorm wrote:if you have the original book, the 4" holes in the hatch are made for the stock rear speakers. dont see them often though.
I was lucky enough to find a set in a car I parted out years ago, they quickly landed in the missus' car.
Squirt wrote: Dude. We aren't a bunch of twelve year olds on MySpace. Just talk normally.....
And I swear you looked 12 when I sold you the ecu squirt
Insert sig here
Hahahaha f**k, nice.southy wrote:SNAP!!Pauly wrote: And I swear you looked 12 when I sold you the ecu squirt
CONVO RACING
NICOLEHUNTERS
NICOLEHUNTERS
Wow,, didn't realize that all u adult men were so serious about ur little toy cars u all play with?
My mistake , I thort this place was more of an easy goin forum where I could just relax be myself & talk a bit of s**t?
I'll try and be a little more appropriate with my grammar so as not to insult the intelligence of the righteous Suzuki elite!
Pffffttt Unlikely
Boot off Gronk, I'll be how I am & u can like it or lump it !
Pffffttt Unlikely
Oniddog wrote:Wow,, didn't realize that all u adult men were so serious about ur little toy cars u all play with?
Pffffttt Unlikely
CONVO RACING
NICOLEHUNTERS
NICOLEHUNTERS
it worries me that you can translate that without google.Squirt wrote:Oniddog wrote:Wow,, didn't realize that all u adult men were so serious about ur little toy cars u all play with?
Pffffttt Unlikely
oh yeah, in my cino, i have the holes, was lucky enough not to score the brake light that's on the hatch (bottom middle of the glass) or any of the plastic that im sure was meant to be there. weight reduction ftw!
97' Cino 5Dr Project. Status: Gone.
