CANT GET POWER TO MY HEADUNIT.!
mk2_gti_E2
- Contact:
blew my accesorie fuse while wiring up my headunit then i replaced the fuse correctly rewired the head unit wired up my amp speakers and sub and the turn my car on still now power on my head unit..WHAT COULD IT BE?
did you check the voltages at the back of the head unit, make sure that its getting power?
oh, and check the fuses relating to your rear lights. that one can blow and take out the constant to your stereo.
97' Cino 5Dr Project. Status: Gone.
mk2_gti_E2
- Contact:
yeh ive checked the mini blade fuse its fine pauly..but my multimeter has gone missing so im gna have to wait for the weekend to get another one and check for power ..thanks guys..is there any other possibilities?
mk2_gti_E2
- Contact:
Thanks for the help guys
problem fixed and the swift is finally PUMPING again
mk2_gti_E2
- Contact:
my 1.5mm power had slit itself open because one of the cable ties that was holding it stable in the engine bay was a tad tooo tight lol
