Suspension Help
Post Reply
wilf
I just Installed some lowered springs at the rears, and now im not only hitting, but sitting on the bump stops. That means I need some stiffer shocks?
Thanks
SOLD:Suzuki Swift GTi - 69KW atw
SOLD:Starlet GT - 137KW atw
SOLD:Suzuki Ignis Sport - Stock
NOW: KAWASAKI ZX-6R
[YLD80Y]
Stiffer shocks won't change the ride height. You either need to trim the bump stops or fit taller springs!
Pugman
wilf wrote:I just Installed some lowered springs at the rears, and now im not only hitting, but sitting on the bump stops. That means I need some stiffer shocks?
Thanks
Yesterday I offered to send the info about cutting the bumpstops for shorter springs. That's why it's needed. I will pm it to you when I get home. OK?
markymark
Thanks
I think the problems have only started. Chances are you will damage your shocks because they will bottom out.
I rang king springs with standard shock for about 9 months and them 12 months with konis. It was better with the konis, but still to stiff for a daily.Then I took out the springs because my back could handle it anymore.
Ghetto engineering in a garage near you
wilf
Oh, Pugman, Was that the issue you were getting at? Sorry i thought you were just saying that I should keep the bump stops. Sorry I didnt get you at that time. I was in a rush, it was noisy and I just kinda noded.
Thanks man
Marky, yea this is only temporary, I will get new shocks asap.
If I could put up with coilovers on the street than these should be fine. 8)
NOW: KAWASAKI ZX-6R
Pugman
OK, this was posted on sisoc.co.uk
http://www.sisoc.co.uk/forum/viewtopic.php?t=5809
As the site is due to close down (today!) here's what it says:
J333EVO wrote:After moving house I came across the information provided by Suzuki Sport with there 20mm lowered springs, this will apply to anyone who has fitted or will fit lowered springs as it will stop the car bottoming out on the bump stops, preventing the cars suspension from working correctly, and making the car very hard and skitterish, and possibly dangerous as a consequence.
On the front bump stops remove 15mm from the top of the bump stop, i.e. the bit that sits against the top mount, not the bottom as this is tapered with the groove cut into it.
On the rears, cut it at the first groove from the bottom of the bump stop, the bump stop has three grooves in total for referance.
HTH
Aaron.
If you're not sure of it then by all means get more advice! Once cut they stay cut.
For info SuzukiSport do (did?) sell some other bumpstops to go with their coilovers, pictured on here about a screen down:
http://www.suzukisport-racing.com/news/ ... index.html
Details 646500-4350 - "S-PRC concept" urethane bump stops
wilf
Thanks for the info Pugman. However I've decided to put them in later now after seeing them on the car. They lower about 40mm, which is quite low leaving a small amount of travel for the shocks even when I trial fitted them with no bump stops. I've decided to get new heavy duty shocks and put them in together, at a suspension shop so it'll be done properly.
NOW: KAWASAKI ZX-6R
[YLD80Y]
Don't forget you'll also need an adjustable rear panhard rod too!
86mk1gti
[YLD80Y] wrote:Don't forget you'll also need an adjustable rear panhard rod too!
Would be a fair bet the Commodore adjustable panhard rod being used on the MK1 GTi's would fit IS as well. :wink:
markymark
Bought a commodore panhard rod to test the theory. Nope the pan hard rod is too short. Off to the machinest I go.
markymark
I have had to commodore pan hard rod lengthened by 110mm and it fits nicely. Although i think only a 100mm extension is necessary. Also one bush and crush tube will need to be machined down a little. Other than that no problems.
Thanks sk4wd drive for helping out.
[YLD80Y]
Any adjustable Commodore panhard rod VR/VS fits straight up. I've seen it done on a few MK1s.
markymark
[YLD80Y] wrote:Any adjustable Commodore panhard rod VR/VS fits straight up. I've seen it done on a few MK1s.
Thats the one that I bought. They are too short for the ignis, therefore need to be extended.
sk4wd
markymark wrote:I have had to commodore pan hard rod lengthened by 110mm and it fits nicely. Although i think only a 100mm extension is necessary. Also one bush and crush tube will need to be machined down a little. Other than that no problems.
Take some photos and do a new thread... :wink:
GTi MOTORSPORT
Been quiet lately..still going to rallies.
[YLD80Y]
Sorry I thought we were still talking MK1. I forgot you had an Iggy.
markymark
I traded the ignis last week so the adjustable panhard rods is for sale. $100 plus postage.
pHr34kY
Contact:
markymark wrote:I traded the ignis last week so the adjustable panhard rods is for sale. $100 plus postage.
RLY? What did you trade down to?
markymark
Subaru forester baby wagon. My wife changed jobs so will be loosing her company car. She doesnt drive manual so it had to go. Good news is that I willl see my gti again in two weeks.
Post Reply
