Circlip
Everything technical and mechanical for the Ignis Sport
Post Reply
IGNIS SPORT
Got a not so good surprise this morning with a big puddle of Gear oil on the floor of my shed.Turns out the left hand drive shaft decided to move out buy and inch from the gear boxs .Knowing there was a recall on IS for there left hand drive shaft circlips whitch were not up to standard I contacted Suzuki and low and behold my one was never done. As I live 100ks plus from my nearest suzuki dealer this was not and option to take it in ,so there sending me the circlip. After removing the drive shaft all seems fine with the only circlip thats iffy is the one at the end of the drive shafts spline,so I expect thats the probleum.Has any body else repaired theres buy them selfs, and is this circlip all that holds the drive shaft from floating out of the gear boxs. :o
IGNIS SPORT
I case anyone is wondering.This is the faulty circlip that you have to replace.
[YLD80Y]
Yes that circlip is what holds the driveshaft in place. The easy way to tell if the recall had been done is the sticker they put in the door jamb.
Suzuki MightyBoy - Three pots and a snail.
IGNIS SPORT
I know it hung in there for some years but over all a pretty piss week design.But you get what you pay for I guess.Glad I repaired it myself thoe that way I know it was done right. :)
redgtimk2
was this a problem with all IS or jus specific years?? and what does this sticker look like??
swift by name and nature
IGNIS SPORT
Recall sticker should look something like this.Usually located in the drivers door A pillar.And as far as I can tell all IS made required the recall , just like the passengers air bag. :)
bzchi
Post Reply
