Ignis Sports 02 sensor
Post Reply
ignissports_aus
Hi guys,
Does any know the details for an after market 02 sensor? The check engine light lit up the other day and Suzuki has checked the car and found the oxygen sensor is faulty. Supply and fitting would be $525.10
If anyone can help source an after market or know the part number from the original manufacturer it would be appreciated.
Thanks James
Red Ignis Sports
suzi sports24
hey there is a bosch one that will fit in its about $80 (i think) you just need to cut the plug off the old sensor and fit to new bosch one, the instructions come with it including the colour matching of wire's. it takes about an hour to do may have to remove exaust bracket to get a spanner in there to undo it.
i have fitted it to mine about 6mths ago, when im at work tomorrow il find the part number for you and post it up.
ignissports_aus
Hi suzi sports24, thanks for the info will await your further reply.
Cheers James
Red Ignis Sports
bzchi
How many k's were on your IS when the light came up? (sorry not specifically related, just interested)
ignissports_aus
Just over 127000 km
Red Ignis Sports
bzchi
Did you ever end up getting this part number?
Interested to know what the result was.
Also, what brand/type of fuel do you use in your Sport? wondering if it's related to the failed sensor.
ignissports_aus
No part number as yet. Getting it done at Suzuki on Friday so they should give me the part number then.
I always use 98 octane fuel usually Shell Optimax and occasionally BP or Caltex 98 fuels. Only twice have I used less rated fuel and that was when we had shortages of 98 fuels.
Red Ignis Sports
suzi sports24
sorry for taking so long the bosch part i fitted to my iggy is: 0 258 986 507 and bosch reconmends replace at 160 000km.
bosch o2 sensor cat : http://www.bosch.com.au/content/languag ... at_WEB.pdf
page 107 is the suzuki listings
page: 163 is the pic
page 123 is the spec re heater and isolated case:
0 258 986 507 – Four wire sensor with 12 watt heater and
ground isolated case.
page 124 is install instructions for sensor
ignissports_aus
Thanks for the info, will keep it for future reference.
Red Ignis Sports
Post Reply
