Got it wired in and working.
Ignition Power (ECU Power) - 24P 206 (Black And Red /W Silver Dots)
Ground (ECU Ground) - 31P 303 (Black And Orange /W Silver Dots)
Throttle Position Sensor Input - 31P 316 (Grey W/ Blue Stripe)
Airflow 1 (Voltage) Input - 31P 326 (Red W/ White Stripe)
Airflow 1 (Voltage) Output - 31P 326 (Red W/ White Stripe)
Injector Ground (Sensor Ground) - 31P 310 (Orange W/ Silver Dots)
RPM Input Signal - 17P 16 (Brown With Silver Dots)
Injector Input Signal CH1 - 31P 309 (Blue W/ Yellow Stripe)
Injector Input Signal CH2 - 31P 321 (Blue W/ White Stripe)
Injector Input Signal CH3 - 31P 331 (Blue W/ Red Stripe)
Injector Input Signal CH4 - 31P 308 (Blue W/ Browny Orange Stripe)
Injector Output Signal CH1 - 31P 309 (Blue W/ Yellow Stripe)
Injector Output Signal CH2 - 31P 321 (Blue W/ White Stripe)
Injector Output Signal CH3 - 31P 331 (Blue W Red Stripe)
Injector Output Signal CH4 - 31P 308 (Blue W/ Browny Orange Stripe)
Ignition Input Signal CH1 - 31P 320 (Green W/ Yellow Stripe)
Ignition Output Signal CH1 - 31P 320 (Green W/ Yellow Stripe)
Ignition Input Signal CH2 - 31P 319 (Green W/ White Stripe)
Ignition Output Signal CH2 - 31P 319 (Green W/ White Stripe)
I need to wire the speed sensor in manually to the greddy for launch control to work as at the moment if the TPS is over 85% it limits the revs in any gear to whatever you set the launch control up at which is annoying as its not sensing that its set off!
Ah well at least by tomorrow it will be complete and then ready for a turbo build in the next month or so
